MrYayez03
Nov 08, 2024Tutor
RBR350 - Port Forwarding issue
Hi all, I am trying to host a content manager server so my friends and I can play, but I am having considerable difficulties. I have done it once before and managed to get it working but not sure w...
- Nov 10, 2024
Hi all,
Just thought I'd let everyone know, after speaking with my ISP, they have assigned me a static IP and it all works good now.
CrimpOn
Nov 08, 2024Guru - Experienced User
The most common cause of port forwarding issues is having "two routers" (often called "Double NAT") when the ISP device is a router and the Orbi is in 'router mode'. Since the PS5 forwarding appears to be open, that is probably not the case here.
Another is that Windows has separate rules for private and public networks. It might be worth ruling out the Windows Firewall by disabling the Firewall (temporarily) to see if that makes the forwarding successful.
MrYayez03
Nov 08, 2024Tutor
Thanks for the reply, I have already tested with the windows firewall disabled for all networks and it made no difference unfortunately.
