Jules32
Apr 24, 2023Aspirant
Rbr350 always magenta
Dear all, l have 2 rbr 350 with one in acces point. Usually l don’t have any problem but now my satellite is always in magenta. Moreover it’s no more visible on the apps despict the fact l still ha...
Jules32
Apr 25, 2023Aspirant
It’s 2 RBR350. No S in the name of the model. l don’t think the distance is an issue since l still have wifi.
Apr 25, 2023Guru - Experienced User
So which of the two RBRs is getting a front PINK LED?
What is the distance between the 1st and 2nd RBR?
How do you have the 2nd RBR setup for AP mode? Static IP or Dynamic IP address configuration?
What is the CAT# LAN cable in between the 1st and 2nd RBR?
- Jules32Apr 25, 2023AspirantThe satellite is always pink.
The distance is maybe 5 meters with 2 light walls.
It’s weird the menu « internet » on the page of the orbit is not accessible. It’s where l could chose between static or dynamic ip
There is no lan cable between the 2 rbr. There is just a cable between the internet box from my internet provider and the rbr use as router- FURRYe38Apr 25, 2023Guru - Experienced User
So the front LED on the RBS connected to the ISP modem is pink?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Really don't under stand your posts. Do you have two RBRs or one RBR and one RBS?
