Max_bb
Nov 07, 2022Aspirant
RBR350 and Daisy Chain
#daisychain #rbr350 Hi (from Paris - France) I need to set my daisy chain on but I can't because the admin UI does not display the check box ! (then no check box in front of Backhaul Topology )...
Max_bb
Nov 08, 2022Aspirant
Hi Thanks for this but in my case, router seems not doing it : daisy chain is not on*,
*satellites 1 and 2 are connected to the router,
physical map : satellite 2 is quite far from the router and closer to satellite 1 which is, of course, closer to the router (like a chain then :-)).
result : devices connected to satellite 1 are not receiving at expected speed (twice less vs ones connected to satellite 2). issue that daisy chain is supposed to solve.
any idea ?
best
Nov 08, 2022Guru - Experienced User
Here's the problem with daisy chain and dual band.
When you have a dual band device (not the tribands with the dedicated backhaul), each hop is going to drop speeds 50%. Reason why is the dual bands have to use the same chip to go router----satellite and then satellite----device. And it can't do both at once. So they're already going to be at 50% speeds just because of how it functions. Add in distance/obstruction/interference and that 50% speed can be much less. Now daisy chain a satellite that has to connect to a satellite thats already running at 30-45% speeds and it goes to the next satellite and take the same 50% speed hit plus distance/obstruction and its running significantly slower than the router/prior satellite.
So the satellites have to negotiate with the router to see if its faster to directly connect to the router that has a higher starting point or the satellite that might have a better signal but much lower speeds. so its not as simple as "it has a better connection". It might have a much better connection but lower speeds.
I don't know 100% but I believe thats why netgear disabled the user options for the AX devices for daisy chain.
The tribands have the dedicated backhaul that prevents as much speed drop.
- Max_bbNov 08, 2022Aspirant
thanks for this very detailed explanation. however, need for daisy chain is not only for high speed. better connection, in my case, is prio #1.
I'll continue to search for a solution (how to set / force daisy chain on) if there is one ! (at the end, this daisy chain capability was the main reason for purchase)
(strange things, here is the html code in the page around this daisy chain option)
<tr><td colspan="2" nowrap="nowrap"><b>Backhaul Topology</b></td></tr>
<TR id='daisy'>
<TD nowrap colspan="2">
<input type="checkbox" name="daisy_chain" onclick="return check_daisy_chain();"><b>Enable Daisy-Chain Topology</b>
</TD>
</TR>wondering if there is not an html issue in addition?
