LexvdH
Jan 04, 2024Aspirant
RBR350 and satellite
I've a glassfiber modem/router which is connected with a 1 Gb switch. The RBR350 has a wired connection with one of the switch ports. In another building I've installed a satellite (wireless) . I us...
CrimpOn
Jan 04, 2024Guru - Experienced User
The fiber needs to be connected directly to the router WAN (internet) port.
Then, the switch can be connected to one of the router LAN ports.
- LexvdHJan 04, 2024Aspirant
The wifi works so the RBR is connected properly. The wired connection is an issue. How do I login in the RBR350 by means of a desktop/laptop?
- CrimpOnJan 04, 2024Guru - Experienced User
Yes, the wired connection is the issue. Satellites must appear to be connected to one of the LAN ports. The router will never detect a satellite which appears to be connected to the WAN port. The WiFi is 'working' because the router is getting an IP address from the ISP through the switch.
If the switch is moved 'behind' the router, everything will work.
There is no 'configuration' to change.
However, if you really want to look at the router web administration, connect that laptop cirectly to one of the router LAN ports.
- LexvdHJan 06, 2024Aspirant
So the configuration is :
Building 1 Building 2
Glassfiber modem/router ---> 1 Gb switch ---> RBR350 ------> satellite ORBI ---> Ethernet ---> NAS
I do see on the ORBI staellite that the NAS is connected by wire.
The Internet works in both buildings (wifi and wired) . On the USB/Ethernet device I see a 1 Gb connection enabled. However, The network in building 1 is not extended to building 2. Looks I need to enable protocols somehow and somewhere.
