AndreaPav
Jan 05, 2022Aspirant
RBR350 e IPoE per Sky WiFi
Buona sera a tutti, ho appena installato FTTH con sky wifi e avevo già una rete con degli ORBI Wifi 6. Volevo utilizzarli direttamente senza router collegando direttamente l'ONT ma non sono riuscit...
- Jan 06, 2022
Ciao to all!
I've finally found the problem. My ISP use IPv6 and I had to manually enable it.
The provider is Sky, and the config is just DHCP + IPv6 + enable VLAN/Bridge with ID 101
Have a good day
Andrea
AndreaPav
Hi!
I have installed a new FTTH network with Sky WiFi.
Now I have a problem, I would like to use my Orbi 6 directly connected to the ONT but i have to use IPoE protocol, and I cannot find it (only PPPoE and others).
Can someone help me? It is supported?
Thank you in advance.
Andrea
Jan 05, 2022Guru - Experienced User
Please contact the ISP for help and information regarding this. They should be able to help you on this. Ask the about there hardware and configuration requirements.
Good Luck.
- AndreaPavJan 05, 2022Aspirant
they told me that i have to find IPoE (and not PPPoE), but i cannot find it.
Is it supported?
thank you
- FURRYe38Jan 05, 2022Guru - Experienced User
If thats not listed in the Advanced tab/Setup/Internet settings and the drop down menu item, then it would not be supported. I know PPPoE is.
- CrimpOnJan 05, 2022Guru - Experienced User
Does the ISP require you to enter a user name and password when connecting?
If not, I would try the "No" option on "Does my internet connection require a login."
This article on the internet points out (in the bottom table) that IPoE authenticates using DHCP, which is what the "No" option does.
https://forum.huawei.com/enterprise/en/pppoe-vs-ipoe-the-difference-between-them/thread/595816-861
not working.... maybe I'm missing something
