AndreaPav
Jan 05, 2022Aspirant
RBR350 e IPoE per Sky WiFi
Buona sera a tutti, ho appena installato FTTH con sky wifi e avevo già una rete con degli ORBI Wifi 6. Volevo utilizzarli direttamente senza router collegando direttamente l'ONT ma non sono riuscit...
- Jan 06, 2022
Ciao to all!
I've finally found the problem. My ISP use IPv6 and I had to manually enable it.
The provider is Sky, and the config is just DHCP + IPv6 + enable VLAN/Bridge with ID 101
Have a good day
Andrea
AndreaPav
not working.... maybe I'm missing something
CrimpOn
Jan 05, 2022Guru - Experienced User
What happens if you connect a desktop or laptop computer directly to the ONT? Does it connect?
I agree that the ISP may be the best resource. I have found that most ISP's have many technical support agents and that the agents vary in their ability to understand questions and provide useful information. Perhaps calling again and being careful not to mention IPoE, explain what you are trying to do and how it fails. The ISP must have countless customers who want to use their own router.
Is it correct to assume that the ONT was originally connect to a router provided by the ISP and you want to remove that router?
- AndreaPavJan 06, 2022Aspirant
Ciao to all!
Have a good day
Andrea
- FURRYe38Jan 06, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
