Nov 11, 2022Follower
RBR350 keeps dropping out after V4.4.1.29_3.10.80 update
My Router keeps dropping out (mostly wifi, but sometimes on cable) following an V4.4.1.29_3.10.80 update. The update was very slow and ultimately I had to do a hard restart of the router. I have tried using the reset button, things seem to work for an hour or two and then it al drops out. The system has been running for about 9 months perfectly until this update. When wifi drops out is it very hard to connect tot eh router using the orbilogin web address, but even whilst in there nothing seems to be an issue.
1 Reply
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
Armor, Circle, Traffic Meter.
