rk_gearorbi
Jan 23, 2025Aspirant
RBR350 not a real mesh?
I have a RBK353, 1 root and 2 satellite. my previous mesh the satellites could also connect to each other and in this one the satellites can only connect to the root. this seems like a poor design fo...
- Jan 31, 2025
Hello rk_gearorbi ,
Welcome to the NETGEAR Community!
I understand that your satellite does not connect to your Orbi router. This issue can be caused by having a different firmware installed on your router. The current firmware for your RBS350 is version 7.2.6.31.
Please update your satellite to this firmware to resolve this issue!
Navigate to the link below for the download file for your RBS350:
https://kb.netgear.com/000066438/RBK653-Firmware-Version-7-2-6-31
Navigate to the link below for step-by-step instructions on how to manually update the firmware on your RBS350:
Best,
Kevin
Community Team
rk_gearorbi
Irrespective of where I place the 2nd satellite it either connects back to the root or just stays offline ... see current snapshot where I placed it where it's a wifi black spot for the root but surely reached by the satellite (store room).
CrimpOn
Jan 23, 2025Guru - Experienced User
Thanks for posting that screen shot. What happens when the satellite is placed on the opposite side from the router, but not so far away?
What is the approximate distance between these units?
- rk_gearorbiJan 23, 2025Aspirant
Same. Connects to root always. And now shows not connected as root does not reach that spot. This daisy chaining does not seem to be working at all. the AP 'master room' is surely in the 5ghz coverage range of 'store room'. but it looks to be looking for the root to connect.
- CrimpOnJan 23, 2025Guru - Experienced User
Actual distances would be helpful.
I was hoping to establish a pattern of
- How far the 2nd satellite would have to be from the router before it chained to the 1st satellite instead of the router, and
- How far the 2nd satellite would have to be before it did not connect at all.
One of the nice features of mesh WiFi is that the satellites are easily moved from one place to another.
- rk_gearorbiJan 24, 2025Aspirant
Thanks. I have been trying various combinations.
hope these help
This has never happened so far.
I have tried it at 15 feet and connected to root on 5 ghz
at 25 feet connected to root at 5 ghz but barely and then drops to 2.4 ghz
around 30 feet cannot connect to root and satellite is about 10 - 12 feet away
