rk_gearorbi
Jan 23, 2025Aspirant
RBR350 not a real mesh?
I have a RBK353, 1 root and 2 satellite. my previous mesh the satellites could also connect to each other and in this one the satellites can only connect to the root. this seems like a poor design fo...
- Jan 31, 2025
Hello rk_gearorbi ,
Welcome to the NETGEAR Community!
I understand that your satellite does not connect to your Orbi router. This issue can be caused by having a different firmware installed on your router. The current firmware for your RBS350 is version 7.2.6.31.
Please update your satellite to this firmware to resolve this issue!
Navigate to the link below for the download file for your RBS350:
https://kb.netgear.com/000066438/RBK653-Firmware-Version-7-2-6-31
Navigate to the link below for step-by-step instructions on how to manually update the firmware on your RBS350:
Best,
Kevin
Community Team
AVDRossem15
Jan 27, 2025Aspirant
I have the same issue. I've been using the setup for two years now and lately it doesn't daisy chain anymore.
Distance between Base and 1st satellite is 8 meters, between 1st sat and 2nd sat is about 12m
Still the 2nd satellite connects to the base though it's about 20 meters away. But backhaul on 2.4
I did a reset earlier to reconnect all units but it does not daisy chain in any way.
- FURRYe38Jan 27, 2025Guru - Experienced User
What happens if you turn down the power on the RBR from 100% to say 50%?
Under Advanced Tab/Advanced Settings/Wireless Settings
- rk_gearorbiJan 27, 2025Aspirant
Not tried that but that's not how the mesh should work. So basically it's a poorly implemented product. Very disappointed with the mesh / daisy chaining implementation of Netgear.
- AVDRossem15Jan 29, 2025Aspirant
Same issue. The far end satellite looses connection all the time now.
And some of the devices that were connected to the base are now not within range anymore. So it's getting worse.
I will try again starting from scratch. I did work earlier so it should do it again.
