Adriangsmith
Jun 29, 2024Tutor
RBR350 not connecting to internet
Hi, I have an RBR350 with two satelites. All has been working well, connected to the internet via a Huawei B818-263 fixed wireless modem on an Optus (australia) connection. With no apparent change f...
- Jul 02, 2024
it turns out, it was related to a change at the ISP level. we have changed to another account and everything works fine again ... thanks for the advice - all resolved
Adriangsmith
Jun 30, 2024Tutor
Thanks for that - strange that it worked for a while and now doesn't.
I've added the orbi mesh to extend the range.
I'll go down that route and report back if it fixes it.
Adriangsmith
Jul 02, 2024Tutor
- FURRYe38Jul 02, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
