Dallas13
Oct 22, 2024Follower
Rbr350 reconfigure
Someone has reset my modem now I’m unable to get it connected or reconfigure the damn thing. Any help appreciated
Oct 22, 2024Guru - Experienced User
If it's the ISP modem then you'll need to contact your ISP about that.
The RBR is not a modem, just a router. Try a factory reset on it and set up from scratch with a wired PC and web browser:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
