andymeakin
Mar 16, 2023Aspirant
RBR350 triggering house alarm
I recently bought a RBR350 mesh system which it turns out is triggering my house alarm. If I turn off the RBR350s, no problem, with them on, it will trigger the alarm immediately up to within a few m...
Mar 16, 2023Guru - Experienced User
What alarm system is it?
Have you tried changing what wifi channels the router is on? or the security system?
Almost sounds like the sensors for the security system are on the same bandwidth and something's broadcast must trigger it.
