Laberrhabarber
Aug 13, 2022Aspirant
RBR350 wired connections and internet constantly dying
I have the same problem.
On my router (AVM Fritzbox 7490) I connected the orbi with option 2 (DMZ) and it worked fine for 3-4 months. Lately I have been having disconnections all the time. First i...
Aug 13, 2022Guru - Experienced User
What FW is loaded on the Orbi system?
There is a new version of FW available
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- LaberrhabarberAug 14, 2022Aspirant
Thank you for the quick reply.
I have now installed the latest firmware (V4.4.1.29_3.10.80).
Subsequently, I have performed a reset on the router and the access points.Now I test it, whether this was the solution and report again in a week at the latest.
One thing I can already say: The interface of the router has become faster.
- FURRYe38Aug 14, 2022Guru - Experienced User
Let us know how it goes...
