Laberrhabarber
Aug 13, 2022Aspirant
RBR350 wired connections and internet constantly dying
I have the same problem.
On my router (AVM Fritzbox 7490) I connected the orbi with option 2 (DMZ) and it worked fine for 3-4 months. Lately I have been having disconnections all the time. First i...
Aug 13, 2022Guru - Experienced User
What FW is loaded on the Orbi system?
There is a new version of FW available
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Laberrhabarber
Aug 14, 2022Aspirant
Thank you for the quick reply.
I have now installed the latest firmware (V4.4.1.29_3.10.80).
Subsequently, I have performed a reset on the router and the access points.
Now I test it, whether this was the solution and report again in a week at the latest.
One thing I can already say: The interface of the router has become faster.
- FURRYe38Aug 14, 2022Guru - Experienced User
Let us know how it goes...
