snoopyy
Aug 28, 2024Tutor
RBR350 with 2 RBS350 I have one of the RBS350'S connected via wired backhaul and other is wireless
I've been trying to fix the issue of not having prominent strong speeds around the whole house which it has kind of struggled with in the past getting only around 120 mbps into the lounge whilst conn...
- Aug 28, 2024
I appreciate the help guys (FURRYe38, CrimpOn), and thank you for clarifying that CrimpOn much appreciated, I think I'm going to stick to this setup as I didn't see any difference in speed in the master bedroom with it wired or wireless but it effected my office ofc as I'm wired to the satellite and it dropped the speed from 950 to 290 once on wireless so unless I'm able to wire all 3 I'm just going to leave them as they are now which is the old setup with the channel switched and the positions slightly changed to make it sufficient
snoopyy
Aug 28, 2024Tutor
I understand what you're conveying and I will attempt what you're asking as it is very informative but I think my message may have been too confusing the main issue I'm having is that both of the satellites are fully operational and working properly, however my router isn't letting any of my devices connect wirelessly for some odd reason I've rebooted the whole system including the modem and waiting for a full reboot and it seemed to have fixed it for a little bit but when I had awoken again the issue still carried on.
CrimpOn
Aug 28, 2024Guru - Experienced User
If both satellites are powered off, do devices connect to the router WiFi?
"Isn't letting devices connect" implies that some error message is being displayed on devices when they attempt to connect. What message is that?
- snoopyyAug 28, 2024Tutor
I'll go and turn off the satellites right now and check if the devices will connect when just the router is turned on.
I don't see any error messages it's just the fact that when I go on the orbi mobile app I am right next to the router or even a couple feet away and it hasn't switched to the router to show I'm connected to it and not the other satellites if that makes sense and when I'm in the master bedroom which is closes to the router I am on only 2 bars which I can see that I'm not connected to the router hence the slower speeds- CrimpOnAug 28, 2024Guru - Experienced User
Is the smartphone the only device connected via WiFi?
What smartphone is the Orbi 'app' running on?
If you open the WiFi Settings, what Link Rate does it show for the phone?
What does the Orbi 'app' say about the phone WiFi connection?
Do any WiFi devices move from one Orbi unit (router or satellite) to another?
For example, laptops, tablets, other smartphones, WiFi speakers (Amazon Echo, Google Nest Mini, Sonos).
