snoopyy
Aug 28, 2024Tutor
RBR350 with 2 RBS350 I have one of the RBS350'S connected via wired backhaul and other is wireless
I've been trying to fix the issue of not having prominent strong speeds around the whole house which it has kind of struggled with in the past getting only around 120 mbps into the lounge whilst conn...
- Aug 28, 2024
I appreciate the help guys (FURRYe38, CrimpOn), and thank you for clarifying that CrimpOn much appreciated, I think I'm going to stick to this setup as I didn't see any difference in speed in the master bedroom with it wired or wireless but it effected my office ofc as I'm wired to the satellite and it dropped the speed from 950 to 290 once on wireless so unless I'm able to wire all 3 I'm just going to leave them as they are now which is the old setup with the channel switched and the positions slightly changed to make it sufficient
Aug 28, 2024Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
How is the wired RBS connected to the RBR? Directly in back or is there a Wall Jack, LAN Patch panel or a LAN switch in between the RBR and RBS?
What CAT# LAN cable is being used? CAT6 is recommended.
What channel configurations are currently set on the router?
snoopyy
Aug 28, 2024Tutor
Firmware version: V4.4.1.29_3.10.80
Sq Ft: 3000
Distance between the first satellite is around 25 feet or so I can't measure completely as they're both in different attics.
The second satellite was under the stairs central to the ground floor but based on what you're saying I need them 30 feet or further for best compatibility so I moved it into the lounge which is similar to how far away the other satellite is
The wired RBS is connected directly into the back of the RBR no switch or wall jacks and is also wired by using a cat 7 Ethernet
The current channel configs on the router are 2.4GHz is on auto and 5ghz is locked to 108(DFS)
