snoopyy
Aug 28, 2024Tutor
RBR350 with 2 RBS350 I have one of the RBS350'S connected via wired backhaul and other is wireless
I've been trying to fix the issue of not having prominent strong speeds around the whole house which it has kind of struggled with in the past getting only around 120 mbps into the lounge whilst conn...
- Aug 28, 2024
I appreciate the help guys (FURRYe38, CrimpOn), and thank you for clarifying that CrimpOn much appreciated, I think I'm going to stick to this setup as I didn't see any difference in speed in the master bedroom with it wired or wireless but it effected my office ofc as I'm wired to the satellite and it dropped the speed from 950 to 290 once on wireless so unless I'm able to wire all 3 I'm just going to leave them as they are now which is the old setup with the channel switched and the positions slightly changed to make it sufficient
CrimpOn
Aug 28, 2024Guru - Experienced User
Is the smartphone the only device connected via WiFi?
What smartphone is the Orbi 'app' running on?
If you open the WiFi Settings, what Link Rate does it show for the phone?
What does the Orbi 'app' say about the phone WiFi connection?
CrimpOn
Do any WiFi devices move from one Orbi unit (router or satellite) to another?
For example, laptops, tablets, other smartphones, WiFi speakers (Amazon Echo, Google Nest Mini, Sonos).
- snoopyyAug 28, 2024Tutor
Like in the same position just hopping from one satellite to another?
I don't believe so only of course when we're moving around the house but that's just automatic selection I assume you mean stationarily and would that mean that the satellites are in too close of a proximity to be effective?
