taj
Nov 08, 2022Follower
RBR350
Hi , I have RBR350 and 2 satellites are hard wired. And RBR350 is set up as access point. When there is Power Outage, one of the satellites do not get connected. At one point there was Magenta light ...
Nov 13, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
All RBS using same version of FW as the RBR?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
