Wizzard370
May 10, 2023Tutor
RBR353 and ethernet cable connection
I have RBR353 mesh - Base (Router) plus 2 satallites. The Base has an ethernet connection to a 16 port switch (devices like PC, scanner, printer etc. feed into this switch.) I want to connect one of...
- May 10, 2023
You can do either. Either would work fine.
What is Ethernet backhaul and how do I set it up on my Orbi WiFi System? | Answer | NETGEAR Support
May 10, 2023Guru - Experienced User
