jtfinnell's avatar
jtfinnell
RBR40 and Orbi Quad-Band WiFi 6E Mesh System (RBKE963)
Not entirely finding the answer online.
Upgrading from the RBR40 to the RBKE963.
I have several satellites from the RBR40 (RBW30).
Are the RBW30 satellites compatible with new system?
Thanks
JT
  • CrimpOn's avatar
    CrimpOn
    Apr 08, 2022
    No, they are not.  The Original Orbi product satellite will not sync with the AX or the WiF6E product lines.  Sorry.
  • Related - also checking to see if this model RBS50 is compatible with the Quad-Band WiFi 6E Mesh System (RBKE963),
    Thanks
    JT
    • CrimpOn's avatar
      CrimpOn
