JustRic
Dec 12, 2023Aspirant
RBR50 as extender to RBRE960 + (2) RBSE960
I upgraded my Orbi system from the AC3000 (RBR50 + RBS50) to the Orbi 960 Series (RBRE960 + (2) RBSE960). Is it possible to use the older Orbi router and/or satellite to extend the new AX11000 system...
- Dec 12, 2023
No as the Orb AC series is NOT compatible with Orbi AX or AXE.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Depending on size of home, the 960 series you have should be suffient and offer better wifi coverage and performances than the Orbi AC series.
Dec 12, 2023Guru - Experienced User
