JustRic
Dec 12, 2023Aspirant
RBR50 as extender to RBRE960 + (2) RBSE960
I upgraded my Orbi system from the AC3000 (RBR50 + RBS50) to the Orbi 960 Series (RBRE960 + (2) RBSE960). Is it possible to use the older Orbi router and/or satellite to extend the new AX11000 system...
- Dec 12, 2023
No as the Orb AC series is NOT compatible with Orbi AX or AXE.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Depending on size of home, the 960 series you have should be suffient and offer better wifi coverage and performances than the Orbi AC series.
Dec 12, 2023Guru - Experienced User
JustRic
Thank you FURRYe38 for that information! The new system does indeed provide faster WiFi and better coverage than my old AC system. I suspect I will not miss the old system much at all. Since the old system still works I thought I would use it along side the new system, if compatible. Since it is not I will see if I can find someone who has something older that might want that system as an upgrade. Cheers!
Ric
Ric
- FURRYe38Dec 12, 2023Guru - Experienced User
You should be good with the 960 alone. I'm enjoying mine currently. Ya I do have the 50 series as well. It's in it's box and used for reference testing when needed. You could keep it as a Just In Case kind of thing. Or find it a new good home that needs good wifi.
Good Luck.
