rupertyip
Mar 18, 2021Aspirant
RBR50 drops internet on 5 GHz only requiring reboot
My Orbi RBR50 (firmware V2.7.2.104) has been acting strange since the firmware update. I noticed that the WiFi connection is strong for both 2.4 and 5 GHz but internet only works for the 2.4 GHz con...
Mar 18, 2021Guru - Experienced User
Also what is your NTP settings configured for? What time zone are you located in?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
