PiotrNH
Feb 06, 2022Follower
RBR50 in AP mode connected to new RB960
I am upgrading to an Orbi 960 and I currrently have an RBR50. Can I put the RBR50 in AP mode and use the two simultaniously to get even more coverage? Has anyone tried this , or will they interfere w...
- Feb 06, 2022
PiotrNH wrote:
I am upgrading to an Orbi 960 and I currrently have an RBR50. Can I put the RBR50 in AP mode and use the two simultaniously to get even more coverage? Has anyone tried this , or will they interfere with each other?
They will not "interfere". They will ignore each other. Even if the old and new WiFi systems have identical SSID's and passwords, they remain two independent WiFi systems. As long as devices do not move around, this will not be a problem. Once a device begins to move, it will not switch seamlessly from one system to the other (and back), which is probably what you are looking for.
Also, the RBR50 can be connected only by ethernet to the primary router, which may be impractical.
Any WiFi access point (or WiFi 'extender'), from any vendor, can be attached to the 960 to expand coverage as long it is clear that only devices that do not move will be happy.
CrimpOn
Feb 06, 2022Guru - Experienced User
