ckong1
Jun 15, 2021Aspirant
RBR50 slow wifi speed with FIOS
Hello, I have gigabit service from Verizon and 3 Orbi devices. The router is connected directly to the FIOS ONT, no Verizon router. Wifi speeds are <400Mbps, usually around 200. Wired connections...
Jun 15, 2021Guru - Experienced User
Confirming you have a RBR50 or somethig else?
"RBR50 slow wifi speed with FIOS"
What are your wired speed with a PC or laptop connected to thr RBR?
ckong1
Yes, RBR50 with two satellites. I have a switch downstream of the RBR, wired speed tests directly to RBR and behind the switch are the same.
- ckong1Jun 15, 2021Aspirant
Sorry, RBR850.
- FURRYe38Jun 16, 2021Guru - Experienced User
Try enabling WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849- ckong1Jun 16, 2021Aspirant
There is no option to set Coexistence to a certain value, only a checkbox to allow it or not.
