jwf2
Nov 22, 2021Follower
RBR750 – can’t connect can't connect to primary network, only to guest
All of a sudden my Orbi (NETGEAR AX4200 Orbi WiFi 6 High-Performance Whole Home Mesh(RBR750) wouldn't connect to the primary network. It will connect to the guest network only. Please help and I h...
Nov 23, 2021Guru - Experienced User
What devices are you trying to connect to the Orbi system?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
