Jorgee
Dec 05, 2023Aspirant
RBR750 — Orbi WiFi 6 Router AX4200 / DNS server configuration
Hello everyone, I have a mesh system (RBR750) with firmware version V7.2.6.21_5.0.20. My router is behind of ISP's router. I want to configure the option "Use these DNS servers". I did the configur...
Dec 05, 2023Guru - Experienced User
What browser are you using to configure DNS?
If, your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Jorgee wrote:
Hello everyone,
I want to configure the option "Use these DNS servers". I did the configuration and save it, but i did not work.
Can anyone suggest any configuration or final solution?
Thanks in advance
Jorge
