Bcovert
May 27, 2022Tutor
RBR750 - adding an outdoor Access Point
Can I add an outdoor Access Point to one of my Satellites via Ethernet? If so what Netgear model?
May 27, 2022Guru - Experienced User
there isn't currently an outdoor satellite for the AX orbi's. And even the AC orbi that is outdoors, doesn't have an ethernet port.
You could look at using a standard outdoor access point but it wouldn't integrate with orbi.
wifiblues
Aug 26, 2022Luminary
hi there - just picking up on this post and curious what functionality would be lost by employing the Orbi outdoor satellite (RBSY50) with an AX RBK750 to gain coverage outdoors.
i have a weatherproof box and tested the RBS750 AX satellite inside - the issue i am finding is that the satellite appears as magenta on the app.
I am also wondering if I can create a shell similar to the RBSY50 and insert the guts of the RBS750 into it!
Thanks
