Betsy_John
Jan 16, 2021Follower
RbR750 - App installation on Android not supported ?
Hey Community , Just would like to find ,if RBR750 app is supported on andriod 9 version ?
michaelkenward
Jan 17, 2021Guru - Experienced User
Do you mean the Orbi app for Android?
Routers don't "support" Android or any other operating system. They just work with them through something like a mobile device.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
