michaeljhoelle
Dec 30, 2021Aspirant
RBR750 - Cannot port forward to PC connected to satellite router
Using latest firmware V4.6.5.14_2.0.54 Computer is running Windows 10 Setup: Spectrum Modem -> wired connection to Orbi base router -> wireless connection to Orbi satellite -> wired connection t...
Jan 10, 2022Guru - Experienced User
Any progress on this?
Setup: Spectrum Modem -> wired connection to Orbi base router -> wireless connection to Orbi satellite -> wired connection to PC
(The PC is wired with a CAT7 cable to the Orbi satellite, which is wirelessly synced with the base Orbi router)
The PC in question can connect to the internet just fine in this configuration, but when viewing the connected devices on the router administration page, the PC is not included. It is also not included on the devices for setting up port-forwarding. I've tried manually setting its static IP for port-forwarding, but the port still couldn't be reached when I tested it.
Is there a way to access this PC from the router admin page or otherwise port-forward to it?
- michaeljhoelleJan 10, 2022AspirantHonestly I just switched to a different computer that had a wireless card. I never did find a solution to the original problem, but it’s been circumvented.
- FURRYe38Jan 10, 2022Guru - Experienced User
Maybe something with prior PC then?
I wouldn't think so. I've port-forwarded from this computer before, using a different router. The computer that I can PF with is connected wirelessly, and the one I cannot PF with is wired.
