michaeljhoelle
Dec 30, 2021Aspirant
RBR750 - Cannot port forward to PC connected to satellite router
Using latest firmware V4.6.5.14_2.0.54 Computer is running Windows 10 Setup: Spectrum Modem -> wired connection to Orbi base router -> wireless connection to Orbi satellite -> wired connection t...
Jan 10, 2022Guru - Experienced User
Maybe something with prior PC then?
michaeljhoelle
Jan 10, 2022Aspirant
I wouldn't think so. I've port-forwarded from this computer before, using a different router. The computer that I can PF with is connected wirelessly, and the one I cannot PF with is wired.
- FURRYe38Jan 11, 2022Guru - Experienced User
So what is the difference between these two PCs one thats working and one thats not working correctly with PF?
- michaeljhoelleJan 11, 2022AspirantThe only difference is how they are connected to the network. The one currently working to host my server is connected wirelessly. The one that wouldn’t work, was wired into my satellite Orbi.
Can you connect the one PC that wouldn't work to the this server to see if it connects correctly there?
