scimini
Mar 04, 2022Guide
RBR750 - Control Panel not Displaying properly and takes a long time to load
For some strange reason, the control panel takes a long time to load and then when it does it is all garbled. Almost like viewing a webpage where the CSS didn't load. While it is loading the titleb...
- Mar 04, 2022
have you tried this firmware version .
Mar 04, 2022Guru - Experienced User
have you tried a different browser?
Try firefox/edge or even a different pc.
- sciminiMar 04, 2022Guide
I've tried Chrome and Edge on the same desktop with the same results. Different computer, the page render is better but clicking on links doesn't load anything.
- plemansMar 04, 2022Guru - Experienced User
- sciminiMar 05, 2022GuideWill give it a try. Have to reset my rbr as I can’t access the firmware upgrade page.
Couple other things I have thought of. It is connected directly to the ONT with a static IP address. Not sure if it matters.
