scimini
Mar 04, 2022Guide
RBR750 - Control Panel not Displaying properly and takes a long time to load
For some strange reason, the control panel takes a long time to load and then when it does it is all garbled. Almost like viewing a webpage where the CSS didn't load. While it is loading the titleb...
- Mar 04, 2022
have you tried this firmware version .
Mar 04, 2022Guru - Experienced User
have you tried a different browser?
Try firefox/edge or even a different pc.
scimini
Mar 04, 2022Guide
I've tried Chrome and Edge on the same desktop with the same results. Different computer, the page render is better but clicking on links doesn't load anything.
- plemansMar 04, 2022Guru - Experienced User
- sciminiMar 05, 2022GuideWill give it a try. Have to reset my rbr as I can’t access the firmware upgrade page.
Couple other things I have thought of. It is connected directly to the ONT with a static IP address. Not sure if it matters.
