scimini
Mar 04, 2022Guide
RBR750 - Control Panel not Displaying properly and takes a long time to load
For some strange reason, the control panel takes a long time to load and then when it does it is all garbled. Almost like viewing a webpage where the CSS didn't load. While it is loading the titleb...
- Mar 04, 2022
have you tried this firmware version .
Mar 05, 2022Guru - Experienced User
Can you access these pages if you disconnect the RBR from the ONT?
Be sure to clear out all browser caches before entering into the RBRs web page.
scimini
Mar 06, 2022Guide
Disonnecting from the ONT and the control panel loads correctly and is responsive. Hmmm, trying tp get rid of the terrible ISP hardware, as it is terrible to manage and underpowered. Also have a terrible double NAT situation as they don't allow bridging or pass throughs. I tried putting the ORBI in its DMZ or making the ORBI an AP but that resulted in their hardware crashing every night. Ugh, was hoping going directly to the ONT would alleviate these issues.
- plemansMar 06, 2022Guru - Experienced User
If their setup allows a DMZ, it isnt just an ONT.
What ONT/gateway is it connected to?
- sciminiMar 06, 2022Guide
Sorry, the ONT is an Adtran Total Access 362. From there it is running to a sr400ac router. It is there that I added the orbi to the DMZ which would cause the sr400ac to crash every 24-36 hours requiring a factory reset. They have locked the sr400ac down from what I can tell which is I why I was trying to bypass it. The ORBI works when connected to the ONT just fine, I just can't access the control panel to make any changes.
- FURRYe38Mar 06, 2022Guru - Experienced User
Have you tried update FW yet?
Can you access the web page if you disconnect the RBR from the ONT?
A factory reset maybe needed...
