scimini
Mar 04, 2022Guide
RBR750 - Control Panel not Displaying properly and takes a long time to load
For some strange reason, the control panel takes a long time to load and then when it does it is all garbled. Almost like viewing a webpage where the CSS didn't load. While it is loading the titleb...
- Mar 04, 2022
have you tried this firmware version .
scimini
Mar 06, 2022Guide
Disonnecting from the ONT and the control panel loads correctly and is responsive. Hmmm, trying tp get rid of the terrible ISP hardware, as it is terrible to manage and underpowered. Also have a terrible double NAT situation as they don't allow bridging or pass throughs. I tried putting the ORBI in its DMZ or making the ORBI an AP but that resulted in their hardware crashing every night. Ugh, was hoping going directly to the ONT would alleviate these issues.
Mar 06, 2022Guru - Experienced User
If their setup allows a DMZ, it isnt just an ONT.
What ONT/gateway is it connected to?
- sciminiMar 06, 2022Guide
Sorry, the ONT is an Adtran Total Access 362. From there it is running to a sr400ac router. It is there that I added the orbi to the DMZ which would cause the sr400ac to crash every 24-36 hours requiring a factory reset. They have locked the sr400ac down from what I can tell which is I why I was trying to bypass it. The ORBI works when connected to the ONT just fine, I just can't access the control panel to make any changes.
- FURRYe38Mar 06, 2022Guru - Experienced User
Have you tried update FW yet?
Can you access the web page if you disconnect the RBR from the ONT?
A factory reset maybe needed...
- sciminiMar 06, 2022GuideNot yet that is next on my list. As soon as I disconnect the RBR from the ONT I can access the control panel immediately without any changes or resets.
- plemansMar 06, 2022Guru - Experienced User
why not just direct connect to the ont then and not through the sr400ac?
- sciminiMar 06, 2022GuideThis is the route I’m attempting which lead to not be able to access the control panel of the rbr to make changes. Once I put the sr400ac back in the middle the control panel works immediately . I’m going to update the FW and try again.
