NicolasSiver
Mar 07, 2021Aspirant
RBR750 - Devices disconnect from satellite and require Wi-Fi reconnection
Hello Community, Looks like I'm a bit late with this question for Netgear Support. I have bought Orbi AX4200 Tri-Band Mesh Wi-Fi 6 System (RBK752-100NAS) at the end of November 2020. Before writi...
Mar 07, 2021Guru - Experienced User
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
You might also try updating FW as well:
NicolasSiver
Mar 10, 2021Aspirant
Tried to switch power output to 50%. It made everything way worse. TV would disconnect after a few minutes.
As for the firmware, it is not available in Admin Dashboard for an upgrade. Is it released for public use?
- FURRYe38Mar 10, 2021Guru - Experienced User
Yes, you can use the link to get it and manually install it.
