Cgfahey
Nov 14, 2023Initiate
RBR750 - I have an original Starlink satilite & router - need to Disable DNS on the Orbi
RBR750 Router Firmware V3.2.16.22 Currently I have the Starlink Satellite connected directly to the Orbi Router and everything works fine I would like to connect use the Starlink Router and tha...
Nov 14, 2023Guru - Experienced User
Why not just connect the orbi to the starlink with the orbi in access point mode?
That'd leave the starlink in control with the orbi managing its own satellites
Cgfahey
Thanks for the suggestion --- did not know I could do that. It looks like this is the directions
T
- Connect the LAN port of your existing modem or gateway to the Internet port of your Orbi router with an Ethernet cable.
- Launch a web browser from a computer or mobile device that is connected to your Orbi network.
- Enter orbilogin.com or orbilogin.net. A login popup displays.
- Enter your admin user name and password.
- Select the ADVANCED tab.
- Select Advanced > Router / AP Mode.
Thanks I will give it a try
Cliff
- FURRYe38Nov 14, 2023Guru - Experienced User
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
