OliveR5
Dec 07, 2021Aspirant
RBR750 - iOS devices fail to get IP address from Orbi + frequent disconnects
For the past 6 months or so, my Orbi RBR750 router & 2 satellites are struggling to keep iPhone & other mobile devices connected to the router. Wifi will drop serveral times during the day. Sometime...
- Dec 07, 2021
CTS Threshold for both 2.4hz and 5Ghz was already set to 2347
Enable AX > Enable 2.4G
Diabling this will not disable the 2.GHz channel as I have several IoT devices that need to be on 2.4Ghz.
Dec 07, 2021Guru - Experienced User
Try setting your CTS Threshold to 2347:
- Go to the web admin portal at http://orbilogin.com/
- Click to the Advanced tab, Advanced left menu, Wireless Settings
- Set CTS Threshold to 2347 for both 2.4hz and 5Ghz networks
- Press Apply
See if that helps. If problems still persist, next try disabling AX mode for the 2.4Ghz band:
- Go to http://orbilogin.com/
- Click to hte Advanced tab, Setup left menu, Wireless Setup
- Uncheck "Enable 2.4G" under the top Enable AX section
- Press Apply
