OliveR5
Dec 07, 2021Aspirant
RBR750 - iOS devices fail to get IP address from Orbi + frequent disconnects
For the past 6 months or so, my Orbi RBR750 router & 2 satellites are struggling to keep iPhone & other mobile devices connected to the router. Wifi will drop serveral times during the day. Sometime...
- Dec 07, 2021
CTS Threshold for both 2.4hz and 5Ghz was already set to 2347
Enable AX > Enable 2.4G
Diabling this will not disable the 2.GHz channel as I have several IoT devices that need to be on 2.4Ghz.
OliveR5
Dec 07, 2021Guru - Experienced User
No. Just the AX mode is all.
- OliveR5Dec 07, 2021Aspirant
Thanks, disabled it. Will update this thread tomorrow on how that went.
- FURRYe38Dec 07, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Nope not since last update as its hard to tell when the firmware updates itself automatically.
You are suggesting:
- Power off ISP modem
- Power off Orbi
- Power on ISP modem
- Once ISP modem is online, wait 1 min
- Power on Orbi?
