BrooklynBoy7886
Jan 05, 2025Tutor
RBR750 - pausing WiFi
Why does the pausing WiFi funcition keep losing it's functionality? One week it works, the next it doesn't, for no reason that I know of. I can hit the Pause on all Devices, and nothing happens. It's the only thing I dislike about the RBR750 router. Otherwise, these routers are great.
1 Reply
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
Any Wifi Neighbors near by? If so, how many?Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageTry disabling the following and see:
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
