TeeeTw0
Jul 19, 2021Aspirant
RBR750 - Port Forwarding/NAT not working with VPN
Hi there - I recently bought the Orbi RKB750 kit - one Orbi RBR 750 and one Orbi RBS 750 Satellite connected via Wifi. I'm running FW V3.2.18.1_1.4.14 on both router and satellite. I'm havin...
Jul 19, 2021Guru - Experienced User
If you set a specific custome PF configuration, then you'll need to disable uPnP as well.
Contact the mfr of this VPN app for additional help and information regarding it.
TeeeTw0
The router from the cable company is a Technicolor CGM4140COM and it's in Bridge mode.
With the Orbi, I tried turning using Port Forwarding and turning off UPnP and also tried turning off Port Forwarding and turning on UPnP and both aren't working. When not running VPN on the client both methods work fine.
Before I had the Orbi system, I was using an Apple AirPort Extreme (with the same Technicolor router) and had no problem with UPnP and Port Forwarding.
I've contacted VPN Unlimited's support but haven't gotten a reply.
Grateful for any other suggestions as to what to try.
