CCADNG
Jan 29, 2022Aspirant
RBR750 - Power cycling issues
Hi All, I have lost wifi connectivity whenever the device is powercycled, initially i didnt know what to do to get back wifi so i had to factory reset multiple times, after a support case troubl...
CCADNG
Jan 31, 2022Aspirant
Thanks for your reply FURRYe38
As i mentioned we moved to new home and had to switch off power on/off for various reasons (placement/install other smart switches etc.)
I have Xfinity Comcast XB7 in bridge mode to connect to Orbi, let me know if there is anything i can provide to help me resolve my issue
Jan 31, 2022Guru - Experienced User
You might update FW and see if this helps. v14 has long caused problems for most users.
- ekhalilFeb 01, 2022Master
It will be useful to see what your Internet Settings in Orbi:
Please login the web interface and kindly provide a screenshot of the page under >> ADVANCED >> Setup >> Internet Setup >>
It's likely that this information disappears after power recycling?
