AlanF100
Feb 16, 2023Aspirant
RBR750 - Static IP Address assignments
I am trying to assign a static IP address to an Amcrest security camera and went into Advanced - LAN Setup - selected my camera from the list shown - entered the IP address I wanted - hit Apply. The ...
CrimpOn
Feb 16, 2023Guru - Experienced User
I just went through this with a new Wyze Pan Cam last week. To be honest, I cannot remember if I powered off the camera before power cycling the router (or not). I can remember High School pretty well, but last week - not a chance!
You are a good sport to endure this mess. Can you try again:
- Power off device.
- Power cycle router.
- Power on device.
I actually have a procedure for adding new devices:
- Before powering the device on for the first time, copy down the device MAC address (or hold the device in my hand)
- Open the Orbi LAN setup table.
- Create an entry in the table for the device.
- (Remember to "APPLY" - got me more than once)
- THEN, plug in the new device.
With this camera, the MAC address was in such tiny print on the camera label that I read one of the characters incorrectly and entered a MAC address that didn't match. (I also RANT about products that do not show the MAC address on the label or on the box, but that's a different issue.)
AlanF100
Feb 17, 2023Aspirant
Hi CrimpOn
Thanks once again for your reply; it is much appreciated.
So I think I will go back to basics and remove the security cameras, factory reset them and then start the installation process as you describe later in your post. This will take me a few days but will try to get it done over this weekend.
- FURRYe38Feb 17, 2023Guru - Experienced User
Something to try on the RBR as well if you can, Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-routerI've seen some wifi devices not handle IP address reservations properly as well on there side of the fence. Sometimes a reboot or power cycle isn't enough, where a factory reset and setup from scratch maybe needed.
