weirdbeardmt
Jun 14, 2024Guide
RBR750 - unstable, satellites keep disconnecting
Hi all, Starting to lose my mind on this. RBR750 + 3 RBS750 satellites running in AP mode. I have a separate DSL router which acts as DHCP; the Orbi is purely wifi. We've got a fairly busy ho...
- Oct 04, 2024
Thought I'd update this because things have settled down a bit. I have re-sited the nodes (mostly forced due to a Fibre upgrade) but this means the Router is now more central and I now just have 2 APs which seem to make sense.
So far I am not seeing the same issue where nodes would disconnect and then not recover.
Jun 14, 2024Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
IF you have factory reset the system and still seeing problems, I'd downgrade to v.21. Others are seeing issues with v.31 that came out a couple of months ago and troubleshooting and resets don't seem to fix the problems they are seeing. So been recommending user to downgrade the RBS first, then RBR lastly back to v.21.
