weirdbeardmt
Jun 14, 2024Guide
RBR750 - unstable, satellites keep disconnecting
Hi all, Starting to lose my mind on this. RBR750 + 3 RBS750 satellites running in AP mode. I have a separate DSL router which acts as DHCP; the Orbi is purely wifi. We've got a fairly busy ho...
- Oct 04, 2024
Thought I'd update this because things have settled down a bit. I have re-sited the nodes (mostly forced due to a Fibre upgrade) but this means the Router is now more central and I now just have 2 APs which seem to make sense.
So far I am not seeing the same issue where nodes would disconnect and then not recover.
weirdbeardmt
Oct 04, 2024Guide
- FURRYe38Oct 04, 2024Guru - Experienced User
re-sited? Do you mean reset?
Glad it's working better now.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- weirdbeardmtOct 07, 2024Guide
No, sorry - I meant 're positioned' - i.e, I changed the location of the router and satellites in the house to try and get a better coverage.
TBH so far nothing material has changed other than this and reducing down to just 2 satellites.
- FURRYe38Oct 07, 2024Guru - Experienced User
So the RBS are keeping connected and working better now?
