LRSS
May 03, 2023Tutor
RBR750 - using a certain Wifi SSID doesn't work but any other SSID does?
I have the Orbi Mesh RBR750, firmware V4.6.14.3_2.3.12. Recently it hasn't been working well; it's hit or miss if devices can connect to the main WiFi network SSID, let's call it "Main". I've power c...
CrimpOn
May 03, 2023Guru - Experienced User
Did this Orbi replace a previous WiFi system that used the same SSID?
Did that system have exactly the same password?
Is that system "gone". (Not broadcasting WiFi any more?)
Might be useful to tell the iPhone to "forget" the SSID "Main", then select it from the menu, enter the password again, and connect.
LRSS
May 12, 2023Tutor
Thank you so much for reaching out. No, this was the same router, I did a factory reset (no other devices broadcasting the old WiFi - I even hard reset the satellites). WHen I went through the process to set-up the Orbi, if I put in the old WiFi network name as the "new" network name, it didn't work, but naming it anything else did.
Thanks again.
