LRSS
May 03, 2023Tutor
RBR750 - using a certain Wifi SSID doesn't work but any other SSID does?
I have the Orbi Mesh RBR750, firmware V4.6.14.3_2.3.12. Recently it hasn't been working well; it's hit or miss if devices can connect to the main WiFi network SSID, let's call it "Main". I've power c...
LRSS
May 12, 2023Tutor
Thanks for trying, but it's not the name itself that's the issue (the characters, spacing, etc.). It's just that specific name - which worked before. It's odd, but I doubt we'll ever figure it out. Thanks for trying to help!
May 13, 2023Guru - Experienced User
I just checked my RBR750, though in AP mode, shouldn't matter.
I copied plain text 2.4 Lake George and pasted it into the Wireless settings.
I use a simple 8 alpha charater password and applied the settings.
All 3 of my wireless devices I have connected, ATT Android phone, iphone 6sP and a iphone 12 pro max. Speed checked thru the phones connected at the RBR.
Wondering if your RBR is in some bad state.
How was the system updated on last FW update? Auto update? Orbi app or Manually?
