Vandervalk
Nov 04, 2022Tutor
RBR750 - Website Login "ERR_CONNECTION_TIMED_OUT"
I do have this problem on a number of similarly run websites. The website administrator says this is my firewall (Orbi Firmware Version V4.6.9.11_2.3.5). I can log in if I use cellular through my p...
Vandervalk
Nov 04, 2022Tutor
Thanks for the reply.
- Only on three websites. Everything else is without issue. What makes me suspicious it's NOT the Orbi is that all these websites are similar databases probably not well managed.
- MacOS 12.6 Monterey. Problems on all devices (desktop, laptop).
- Began about four to six weeks ago. I haven't monitored Firmware updates. I'd purchased and installed the Orbi in June and, besides the usual initial set up teething, I have been headache free.
CrimpOn
Nov 05, 2022Guru - Experienced User
Vandervalk wrote:
- all these websites are similar databases probably not well managed.
I assumed that access is using a web browser. (not some other application)
By coincidence, I am also a Spectrum customer. If this is somehow tied to Spectrum, maybe it affects me as well.
- VandervalkNov 05, 2022Tutor
Yes, they are accessed via browsers.
The main one, I can get to the website. But the issue is not being able to log in. The login in fails with "ERR_CONNECTION_TIMED_OUT" As you're likely not a user, you won't be able to test this.
The other site I can't even browse to the site.
Best,
Van
- CrimpOnNov 05, 2022Guru - Experienced UserI'd be happy if the web site appears at all.
