Chester0711
Aug 17, 2023Aspirant
RBR750 + 4 satellites as AP’s
I am confused as to how Access Points are supposed to behave where connections are concerned. If I setup my RBR750 and satellites to use as access points, how would a mobile phone connected to WiFi be...
Aug 17, 2023Guru - Experienced User
It's up to wifi devices to pick and choose where they connect too. Orbi just provides the platform is all.
Disable the wifi radio on the wifi device for 5 seconds them move closer to the nearest RBS or RBR, then re-enabled the wifi radio on the wifi device. It should connect to to the closer signal.
Chester0711
Thank you, yes I have tried that. It sort of works but then when I leave the house and come back it starts all over again. But I understand it is probably a limitation to the device more so than the satellite or network itself
- FURRYe38Aug 18, 2023Guru - Experienced User
Most likely.
What is the distance between the router and 📡 satellite(s)?
