Chester0711
Aug 17, 2023Aspirant
RBR750 + 4 satellites as AP’s
I am confused as to how Access Points are supposed to behave where connections are concerned. If I setup my RBR750 and satellites to use as access points, how would a mobile phone connected to WiFi be...
Chester0711
Thank you, yes I have tried that. It sort of works but then when I leave the house and come back it starts all over again. But I understand it is probably a limitation to the device more so than the satellite or network itself
Aug 18, 2023Guru - Experienced User
Most likely.
What is the distance between the router and 📡 satellite(s)?
